94 Warrior LOST SPARK!! HELP!!!
Old Jun 24, 2009 | 08:26 PM
cms10balla's Avatar
Default 94 Warrior LOST SPARK!! HELP!!!
i got a 1994 yamaha warrior 350 and i was going down a bumpy hill and it cut out on me and turns over and has good compression and is getting gas but no spark? what can i be? it has a new starter in it. cdi box? coil? please help i wanna get back out and ride=]
Old Jun 24, 2009 | 10:09 PM
cms10balla's Avatar
plz help
Old Jun 25, 2009 | 01:36 AM
91Warrior357's Avatar
going to have to check basic grounds and stuff to make sure all your wiring is fine and its not something simple, most likely if nothing came undone or anything in the wiring harness then it might be the stator that finally pooped out, its pretty common on stators and you have to ohms test them to see if there good or bad
Old Jun 26, 2009 | 11:32 PM
laxattack99's Avatar
yea that happened to me, it shut off on me and it couldnt get it started again. It was turning over with the electric start but wasn't catching. The coil went bad so i replaced it and it started right up. Theyre pretty cheap on ebay, only about $20-30
Old Jun 29, 2009 | 06:16 PM
gatorno12000's Avatar
Default stator
Even if you put a new stator on it recently it could be defective ,it has happened to me twice check your source coil ohms first. I found out by taking apart the source coil in one of the ones gone bad which I bought from flebay that rebuliders use low grade enamelled wire ,mine only lasted a couple of days.Never had a cdi ,pick up coil or spark plug coil gone bad on my 2000 350 warrior .
Old May 2, 2010 | 02:36 PM
2Owanage's Avatar
what wires do i need to test to test the stator and can i test the coil?
Reactant
Mar 30, 2022 02:08 AM
STLyamwar
Jul 25, 2020 04:44 AM
Big bousse
Sep 26, 2015 10:42 AM
manuelrivera
Aug 8, 2015 04:34 PM
suzukiquadrunner1987
Aug 6, 2015 05:29 PM
