'03 sportsman won't start
Old Jun 25, 2009 | 03:49 PM
rudd21's Avatar
Default '03 sportsman won't start
Alright to make a long story short, I put a 1998 sportsman engine into a 2003 sportsman frame. Now that I've fianlly got everything together, I can't get the engine to fire. It turns over real good with the starter and I'm getting good spark, but it still won't run. I don't think its a fuel issue as I've tried squirting gas right into the carb with no luck. What could I be missing? I haven't checked the compression, but just from pulling the rope it seems to be good. Thanks
Old Jun 28, 2009 | 05:47 PM
albertaborn's Avatar
this place will help you if its a crab of fuel issue but id be curious about how much comp there actually is buying a tester will suck but be handy forever if you got gas and air and spark i mean you got every thing
Motorcycle Carburetor Theory 101
Old Jun 28, 2009 | 07:04 PM
danparkcityut's Avatar
Are you sure the engine was able to run normally before the install? If not, it could be a lot of things... timing might be a good place to start...
whitty
67
Feb 24, 2021 02:52 PM
neilbedwell
Nov 10, 2018 11:02 AM
gfl0224
Jun 27, 2015 06:52 PM
Raccar1
Jun 18, 2015 02:17 AM
1000gade
May 27, 2015 12:37 PM
