Kodiak 400 running problem
Old Jun 30, 2009 | 06:00 PM
400sbk25's Avatar
Question Kodiak 400 running problem
Ok so this thing has been sitting for 5 years or so and my neighbor said if i could get it running i could have it! SO i can get it to idle with the choke all the way on. The second i go to put the choke at half it dies and back fires a little and if i try to give it any throttle it like bogs and wants to die.
Anyone have any ideas?
Old Feb 27, 2010 | 06:06 AM
doughchvy1's Avatar
i was having problems also with my 95 kodiak. would idle but soon as i touched the throttle it would die. i know these quads are cold blooded and need time to warm up but that was just crazy. i pulled my carb off and pulled everything out of it and cleaned it really good. now it is hard starting but once is starts it runs like a champ. still running out some old gas. i hear that the needles in the carbs varnish up real quick with older gas.
Old Feb 27, 2010 | 09:59 AM
dupont's Avatar
If you can (depenting if you know how) , buy a rebuild kit for $20 and rebuild the carb.
Old Feb 27, 2010 | 02:16 PM
YAMABOND's Avatar
ok so this thing has been sitting for 5 years or so and my neighbor said if i could get it running i could have it! So i can get it to idle with the choke all the way on. The second i go to put the choke at half it dies and back fires a little and if i try to give it any throttle it like bogs and wants to die.
the slow speed circuit or pilot jet is plugged,,,the choke overides the circuit but as soon as the choke is off , no good ! The casb needs a good cleaning and use air pressure ,not just the squirt of carb cleaner from a can !
kodiak450.
Jun 17, 2015 02:22 PM
generalpops
Jun 5, 2015 08:23 PM
generalpops
Jun 3, 2015 08:25 PM
MrElussive
Nov 10, 2000 05:05 PM
X-2wheels
Mar 14, 2000 09:44 AM
