1988 300 fourtrax
Old Jul 12, 2009 | 04:00 PM
300 4trax's Avatar
Thumbs up 1988 300 fourtrax
I recently bought a 1988 300 fourtrax and need to rebuild the rearend. Can anybody help?
Old Jul 12, 2009 | 09:52 PM
fourtraxhonda300's Avatar
I rebuilt the rearend in mine, What exactly is wrong with yours? Does it need a new ring and pinion or just bearings?
Old Jul 13, 2009 | 07:32 AM
300 4trax's Avatar
I have it tore down and it needs bearings and ring and pinion. The pinion gear has teeth broke off. I'm having a problem getting the pinion gear out of the housing. I can't break the nut loose. How did you get yours off?
Old Jul 13, 2009 | 07:50 AM
atv parts plus's Avatar
put something against the pinion and use air on it then ull need a special tool to remove retainer ring .The big problem is removeing rear pinion bearing i cut them out they dont make a puller for it!!! Sometimes id have to put alittle heat to the houseing to remove retainer nut.
Old Jul 13, 2009 | 07:54 AM
300 4trax's Avatar
Appreciate it I'm going to try it this afternoon. Where did you buy your parts?
Old Jul 13, 2009 | 08:46 AM
I sell parts the rear diff complete is $765.00 new,The rear kit bearings and seals including brake drum seal and bearing is$132.50,The ring and pinion is $285.00
wendal
May 9, 2024 09:29 PM
Valder
Nov 28, 2020 07:38 AM
wendal
Oct 31, 2017 03:31 AM
wendal
Sep 15, 2015 01:50 PM
Steeldon
Sep 8, 2015 10:51 AM
