Tightening of center drive chain
Old Jul 13, 2009 | 01:03 PM
tizzler110's Avatar
Default Tightening of center drive chain
Hey Guys,
I have a 97 Polaris magnum 4X4, and I am kind of new at the whole general repair thing. I have changed all the fluids and replaced a busted started last week; however, I am getting stumped on tightening of the center chain on this thing. I have tried to follow what the manual tells me to do but still seem to be lost. Any thoughts?
Thanks,
Tyler
Old Jul 13, 2009 | 02:06 PM
02magnum500's Avatar
Gets his share of deer.
You should just be able to loosen the cap screw just above the front sprocket on the center drive chain and adjust to 1/4" freeplay on the chain. The adjuster bolt should have a groove to slide in for adjustment. Hope this helps.
Old Jul 13, 2009 | 06:05 PM
Kerbbirds's Avatar
loosen the eccentric bolts spray the eccentric with wd 40 or something like that and sometimes you have to really rock the four wheeler to get it to tighten up i broke a lot of punches doing it the first time
Old Jul 14, 2009 | 10:07 AM
hoopduerr's Avatar
Im working with him on this, does the whole eccentric housing move or jus the internals to the eccentric. We put the screw driver through the sprocket into the eccentric hole and rocked er good and ended up breaking part of the eccentric hole. No internal damage though, that was good.
Old Mar 25, 2010 | 03:43 PM
kidcurry's Avatar
So what did you do about the piece that brook off
Old Mar 26, 2010 | 07:20 AM
Kerbbirds's Avatar
You can take a large rod or something large and long and hit on the ears of the eccentric , it moves toward the rear, dont hit it hard enough to break the ears, did you loosen the bolts enough and spray it good with some lube?
Hondapolaris8596
Jul 28, 2016 03:17 PM
Hankey Pankey
Jul 31, 2015 05:50 PM
WilliamBos
Jul 22, 2015 04:20 PM
joeyupton
Jul 14, 2015 11:51 AM
tporath
Jul 11, 2015 12:31 PM
