'04 Sportsman 500 Stalls when below 3/4-1/2 tank?
Check to see if the vent is plugged, I put a small amount of air pressure to the tank and listen to hear air escaping from vent, it is under the plastic on top of the tank and vents at the headlight, if its venting then the fuel pump could be bad, non efi models have a mikuni style pump located above left front wheel.
