2002 sportsman 400 clutch removal how to?
Old Jul 27, 2009 | 02:08 PM
TIGER DS's Avatar
Default 2002 sportsman 400 clutch removal how to?
2002 sportsman 400, wondering what is needed to take apart clutch, and check one way bearing for EBS(Engine braking system)...and remove the bearing
Is this bearing expensive or? I live in Canada
also do I need special tool, or is there a short cut way to remove anything? and specifics would help. thanks...
And is teher a proper way or tool needed to put it back together as well...Thanks
Old Jul 27, 2009 | 02:17 PM
TLC's Avatar
TLC
To remove the Drive pully you need The VST T-Handle Clutch puller Part# 2870506. and a strap wench to hold the clutch from turning as you use it.
Here is a link to the process. http://books.google.ca/books?id=nLsm...esult&resnum=1
Old Jul 27, 2009 | 07:28 PM
TJ400's Avatar
I do believe the 2002 400 Sportsman didn't come with factory EBS... I know my 400 hasn't got it... better double check before tearing into the primary looking for something that might not be there... tj
Old Jul 27, 2009 | 07:42 PM
TLC's Avatar
TLC
The easy way to know is it should be printed "EBS" on the belt cover.
Old Jul 27, 2009 | 11:39 PM
bcdudley's Avatar
This video should help with removing the clutch. It helped me.
YouTube - Changeing belt POLARIS ATV
bzdok1234
30
Feb 23, 2016 01:55 PM
coldnorthpol
Jul 14, 2015 11:22 PM
coolguy420
Jul 10, 2015 01:17 AM
Shifts
Jul 3, 2015 07:59 AM
Jiggypete
May 30, 2015 07:55 AM
