1998 trailboss 250, losing power?
Old Jul 28, 2009 | 11:09 AM
vinman18's Avatar
Default 1998 trailboss 250, losing power?
Hello, My 98 trailboss 250 2 stroke, seems to be losing power its just started to happen in the last few months. When im just cruising and i get on it, it dosent go to near as high RPM as it used to, so its top speed is lower. It seems to have less low end torque as well. It still runs and drives fine. Does anyone know what the problem is? Is it just getting old, and is there anything I could do. Thanks for any help.
Old Jul 28, 2009 | 11:52 AM
drlang's Avatar
Look into the clutches, bet the answer is in there. Also take a compression check. Doc
Old Jul 28, 2009 | 07:14 PM
vinman18's Avatar
ok, what am i looking for in the clutches.
Old Jul 28, 2009 | 07:22 PM
eggenz7's Avatar
check belt and the secondary buttons. also give a good look at the drive clutch just ot make sure theres not anything that looks out of place
Old Jul 28, 2009 | 09:47 PM
ftwflh's Avatar
IF clutch buttons in the secondary are good do a compression leak down test to check the crank seals
Old Jul 28, 2009 | 10:54 PM
vinman18's Avatar
Alright the clutches and drive belt look ok, I'll do a compression check, what should the compression be at?
Old Jul 29, 2009 | 05:56 AM
ftwflh's Avatar
comp needs to be over 100psi cold
Old Jul 29, 2009 | 05:34 PM
vinman18's Avatar
Cool ill get that tested thanks a lot guys.
2quiker
Mar 22, 2022 08:36 PM
mywifesquad
8
Sep 21, 2015 08:20 AM
Slagpolaris
Sep 5, 2015 09:41 PM
toonces
Sep 5, 2015 01:14 PM
