Carb Leaking after cleaning
Old Jul 29, 2009 | 06:50 AM
Ragelite's Avatar
Question Carb Leaking after cleaning
Sportsman 600 twin. After tear down and cleaning it seems to be leaking when I give it hard on the throttle from what looks like a little tit at the bottom of the carb. Any thoughts what?
Old Jul 29, 2009 | 09:34 AM
02magnum500's Avatar
Gets his share of deer.
Probably normal, mine all leak a bit of gas out the overflow in the carb, could be from bouncing around and such.
Old Jul 29, 2009 | 10:03 AM
Ragelite's Avatar
Ive never seen it before, but at the same I was never looking for it. Its something I just say after I did the cleaning. But why would it leak out?
Old Jul 29, 2009 | 12:13 PM
garyc660R's Avatar
You probably tweaked the float during cleaning. Lowering the float level should help.
Old Jul 29, 2009 | 12:42 PM
Ragelite's Avatar
lol lower it? does it not go in only one way? Sorry but its my first time taking a carb apart and I have no clue about lowering it.
Old Jul 29, 2009 | 08:21 PM
eggenz7's Avatar
the brass arm that is connected to the inlet needle.. if you bend the little tab to touches the inlet needle it moves it one way or another. move it closer to the carb body and it lowers the float level. move it away from the carb body and it raises the float level. specs call for +/- 1/32" float arm to carb body so pretty level
Old Aug 4, 2009 | 06:19 AM
Ragelite's Avatar
I was pretty easy on it when I took it apart. Looks like Im taking it apart again to check the float.
Robbbb55
CAN-AM (BRP) Ask an Expert!
Jul 8, 2015 02:16 PM
Robbbb55
Jul 8, 2015 02:11 PM
honda71
Jul 8, 2015 02:13 AM
tweeder
Jul 5, 2015 01:57 PM
J-Mack
Polaris Side by Sides
Jul 4, 2015 04:19 PM
