Carb Leaking after cleaning
Sportsman 600 twin. After tear down and cleaning it seems to be leaking when I give it hard on the throttle from what looks like a little tit at the bottom of the carb. Any thoughts what?
You probably tweaked the float during cleaning. Lowering the float level should help.
the brass arm that is connected to the inlet needle.. if you bend the little tab to touches the inlet needle it moves it one way or another. move it closer to the carb body and it lowers the float level. move it away from the carb body and it raises the float level. specs call for +/- 1/32" float arm to carb body so pretty level
250, bear, beartracker, bottom, carb, carburetor, inlet, installation, leak, leaking, needle, overflow, tracker, works, yamaha
