Scrambler 50 question
Old Jul 30, 2009 | 11:47 PM
hank03's Avatar
Default Scrambler 50 question
I just bought my son an '02 Scrambler 50 and have a question. Is it normal for the engine to go from idle to approx. 1/4 throttle? It seems as if there is no throttle variation while going slow. I did some troubleshooting (pulled the cover off the thumb throttle) and found that as soon as the throttle switch is released the RPM's go up to about 1/4 throttle - without the throttle cable being moved, then ATV starts moving.
Maybe this is normal, but I don't have another one to compare it to. Otherwise the machine is great.
Thanks!
Old Jul 31, 2009 | 08:47 AM
LT80's Avatar
LT80 Expert
Welcome to the forums.
No, it's not normal. Check to see if the cable is adjusted too tight. Pick up on the cable at the carb. There should be a slight bit of free play.
Revving can be a sign of an air leak. Spray carb cleaner around the carb/reed cage and see if the rpm's change.
Let's go from there.
Old Aug 2, 2009 | 04:08 PM
hank03's Avatar
Thanks for the help. I checked the cable adjustment ant it was ok. I assumed since it was idling fine, the idle adjustment was set properly. I was wrong.. after backing off the idle screw it is now working fine. I think the carb needs cleaned, so i'll be getting to that in the near future.
Any idea what the premix ratio should be for these? I would like to remove the oil injection as it doesn't seem to be very consistent (sometimes smokes too much)
Thanks!
Old Aug 3, 2009 | 06:11 PM
LT80's Avatar
LT80 Expert
I run a good synthetic oil at 32:1
fordfaithful21
Dec 7, 2015 05:52 PM
MooseHenden
Sep 6, 2015 04:24 PM
Logan Collins
Sep 5, 2015 08:03 PM
jeff mc
Dunes and Dune Machines
Sep 3, 2015 07:47 PM
DeFox500
Jul 26, 2015 06:32 PM
