Rear outside boot problem.
Old Jul 31, 2009 | 07:40 AM
wajr's Avatar
Default Rear outside boot problem.
Hello everybody. It has been a while since I posted in this forum. So long that in the meantime I forgot my username and password and had to create a new. Anyways, I'm having an issue with the rear right outside boot. It looks to be severely twisted and possibly damaged. Before I take it in I was hoping for some feedback on whether I need a completely new boot. Here are some photos and thank you for the input. The first two photos are of the boot I'm having trouble with and the second photo is the way it should obviously look. Big difference. Is this something that can be fixed at home?
File Type: jpg
Old Jul 31, 2009 | 05:45 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
did you check the clamps to see if they loosened up and maybe spun? if its not ripped or doesnt have a hole in it, then try takeing say the small clamp off and see if you can un spin it and check it out good.
Old Jul 31, 2009 | 07:16 PM
The Kid's Avatar
looks like maybe the big clamp might have grabbed the outer housing causing the boot to spin, i have seen that happen before
Old Jul 31, 2009 | 07:54 PM
Speeddrive1's Avatar
Could have been a small rock that got wedged inbetween the housing and big clamp causing it to twist.
Old Jul 31, 2009 | 11:46 PM
caperinmuskoka's Avatar
Ride like you own it, Not like it's stolen!
It should be WET TO TOUCH with grease if there is a hole or leak......With it turned and compressed that much the Boot should be wet if there is a hole . Forced out.....Caper.......
Old Aug 1, 2009 | 12:57 AM
bcdudley's Avatar
Yup, as long as it is not torn, it should still be fine. It is just a protective cover after all. I would pull it back and make sure everything looks good inside it just for good measure, but you should be fine.
Old Aug 1, 2009 | 08:44 AM
switzomatic's Avatar
Default Boot
Ditto on the last post. If you are not having cv issues then straighten it out and reclamp it.
toonces
Aug 5, 2015 05:55 PM
toonces
Jul 28, 2015 01:58 PM
TLC
3) General Discussions..
8
Jul 26, 2015 11:09 AM
TLC
Jul 25, 2015 02:24 AM
tporath
Jul 11, 2015 12:31 PM
