Swingarm bushing replacement ?'s
I just replaced the axle bearings on my 06 trail boss 330 and noticed that the swingarm has a little side to side play in it. I was just woundering if the swingarm has to be removed or can the bushings be replaced with it on the quad. Also what does the bolts on the clutches need to be torqued at when I reinstall them and the torque for the swingarm bolts.
It all needs to be torqued.Dont just get swing arm bushings.You may need the brass bolt too.It has a tendency to wear too.Try tightening the swingarm bolts and nuts first.
