Swingarm bushing replacement ?'s
Old Aug 4, 2009 | 07:11 PM
hypergt's Avatar
Default Swingarm bushing replacement ?'s
I just replaced the axle bearings on my 06 trail boss 330 and noticed that the swingarm has a little side to side play in it. I was just woundering if the swingarm has to be removed or can the bushings be replaced with it on the quad. Also what does the bolts on the clutches need to be torqued at when I reinstall them and the torque for the swingarm bolts.
Old Aug 4, 2009 | 07:23 PM
ftwflh's Avatar
It all needs to be torqued.Dont just get swing arm bushings.You may need the brass bolt too.It has a tendency to wear too.Try tightening the swingarm bolts and nuts first.
Old Aug 4, 2009 | 08:21 PM
hypergt's Avatar
That was my question what are thay to be torqued at.
Old Aug 5, 2009 | 05:58 AM
hypergt's Avatar
pump
STLyamwar
Jul 25, 2020 04:44 AM
Nondem
Feb 22, 2020 12:20 PM
toonces
Jul 28, 2015 01:58 PM
mdrkcckv
Jul 22, 2015 09:10 AM
95wolv
Jul 21, 2015 12:25 PM
