Locktite yes or no
Old Aug 6, 2009 | 07:41 AM
hypergt's Avatar
Default Locktite yes or no
Getting ready to put my swingarm back on my 06 trail boss and needed to know if I should use locktite on the pivot bolts and also the clutch bolts. There didn't seem to be any on them when I disassembled everything but I did notice some type of blue looking grease on threads of the pivot bolts. If I do need to use locktite what color should I use.
Old Aug 6, 2009 | 04:24 PM
bcdudley's Avatar
I always use locktite on all my bolts. The one time I didn't a few weeks ago, it came back and bit me. I like the red locktite for high strength and temp.
Old Aug 6, 2009 | 04:25 PM
scootergptx's Avatar
Supersock
Hired Gun!
If you want to take the bolt back off again, use blue.
Red will be labled as Loctite, blue will be labled as thread locker.
Old Aug 6, 2009 | 04:54 PM
ftwflh's Avatar
Use blue ONLY on things you want to get apart later.Red can pull the threads.
I would use it on swingarm parts but not the clutch bolt.
Old Aug 6, 2009 | 05:36 PM
mywifesquad's Avatar
KTM Patrol
Former Chinese POW!
I use Blue on any bolt/nut size 8mm and smaller...Red on the larger bolts....Thats a 8mm bolt/nut, not a bolt/nut that uses a 8mm wrench..
Old Aug 7, 2009 | 01:21 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
red, only if you dont want to take it apart again. blue is good for help w/vibration loosing up bolts/nuts.
Dudenhymer
Jun 4, 2013 12:47 PM
mboyda
May 26, 2009 05:45 PM
OffRoadNoob
Jan 15, 2007 12:37 AM
Katuzo
Aug 22, 2006 08:48 PM
KCRider
Apr 5, 2005 03:36 PM
