Locktite on predator flywheel nut???
I've stripped two crank timing keys on my 03 preddy because like an idiot I didn't torque the flywheel nut down properly. This time gonna do it right and get a torque wrench. Any downside to putting a little locktite on the threads to make sure it doesn't happen again??
Thx.
Thx.
Only getting it back off.. I use locktight on almost everything.. NEVER USE IT ON CARBS!! lol. Otherwise, crank that baby down and enjoy knowing nothing will rattle loose. Also, make sure you didn't forget to put anything else on..
USE lock tite,had one 500 flywheel nut loose,shearing flywheel key! 08 sportsman 500 ho carb model with only 12 hrs!! RED loctite preferred as can impact off! Good luck
Don't have the Predator manual,but the three places I've seen posted show 111 to 125 foot pounds which sounds high to me. This link to a cheap $6.95 pdf service manual is your best bet unless someone on the forum has one that can verify the torque specs. ATV POLARIS PREDATOR 500 SERVICE MANUAL ( 2003 2004 2005 2006 200...
chingchangchong
Aug 7, 2022 11:36 AM
Scooter's Shop
23
Oct 22, 2015 07:04 PM
