Help, rear drive shaft removal
I have a 1996 Polaris 500 sportsman, I need to change out the rear universal joints. I have a shop manual and have followed the directions. I have the bolt backed out as far as possible that holds the joint to the transmission. My problem is that the shaft (joint) will not let go of the transmission. I have sprayed it and let it soak over night, and I tried to pull it by hand, but it will not release.
Any suggestions on how to remove the joint (shaft) ?
thanks
rust
thanks
rust
I do not see a pin? There is a bolt that holds the yoke onto the tranny. I have backed the bolt off as far as i can, I have attached a 3/8 rope in through the universal, and hooked it onto a come along and put strain on the rope to try and pull it away from the transmission. ( I have another rope on the opposite side to prevent bike from sliding sideways).
I have sprayed the yoke area with PB Blaster, and have let it soak. Tapping on the yoke with a rubber tipped hammer, but it is not moving, any suggestions???
thanks
rust
thanks
rust
I do not think heat is a good idea, there are seals behind the yoke- heat may damage them. The bolt will come out- when the yoke slides off- thats the way it looks in the manual.
Any ideas- anyone- on how to remove the yoke? I am open to all suggestions.
Thanks
rust
Thanks
rust
Use a slide hammer , it will come out.I rig a small piece of chain around the shaft by the inner joint, hook it to my slide hammer and give it a few whacks, some are stubborn but they come off.
thanks Kirbbirds, but I was able to change the inner universal without removing the yoke. I had to remove a lot of parts around the area- so I had room to use a press type universal joint removal tool.
I changed two u joints- inner on the right side and outer on the left side, the other two were OK.
Glad that is over with, but it gave me a chance to inspect all the suspension parts- all OK !
If I ever have to remove the yokes- I will use your idea.
Thanks
rust
Thanks
rust
