Would this indicate a new clutch is needed???
Old Aug 20, 2009 | 09:51 AM
beergut's Avatar
ʇsıʇɹɐ ɹǝʌolloɹ
Default Would this indicate a new clutch is needed???
I was going through some deep water the other day (more mud then water) maybe 28" - 30" deep.
I got stuck in the middle when my bike would no longer turn any of the 4 tires (4x4).
The bike didn't stall- it just wouldn't spin the tires. Sort of like when you pinch the blade in a log when using a chain saw. And yes, I was in 1st gear...
I winched myself out and continued riding like usual.
I figured maybe one of two things... either my 300 didn't have enough HP to turn all four wheels in the deep thick mud, or my clutch plates weren't grabbing.
I don't have any problems climbing steep fills in 1st gear fwiw-
any thoughts?
Old Aug 20, 2009 | 10:16 AM
budedm's Avatar
If it sounded like when you pinch a chain saw, it's your first guess about a lack of power. If the clutch was slipping, the engine would have revved up with no tire movement. But since it sounded like a pinched saw and bogged when you hit the throttle, there simply wasn't enough power to rotate the tires in the muck.
Old Aug 20, 2009 | 10:30 AM
beergut's Avatar
ʇsıʇɹɐ ɹǝʌolloɹ
great- maybe time to upgrade to a larger ATV.... I need a loan!
Old Aug 20, 2009 | 01:48 PM
action450s's Avatar
Yeah, sounds like a lack of power if it "bound up" in first gear. If the clutch slips it can usually be adjusted before it has to be replaced.
Rocketx
Nov 16, 2020 07:25 PM
jrooker6
Ask the Editor
11
Apr 21, 2016 07:35 PM
alix
Jul 1, 2015 10:33 AM
FourWheelOverTwo
May 31, 2015 07:26 PM
