A-arm bushings?
Old Aug 29, 2009 | 09:53 AM
readymixer169's Avatar
Of all the things I've lost in life, I think I miss my mind the most!
Default A-arm bushings?
Was doing service on the 02 magnum and noticed the A-arms have a little play in them. Not up and down just foward and back maybe a 1/4" of play. Grabbed a hold of the 06 sportsman and it feels very snug no play at all. I don't see to much wear on the bushings. Unless they have just compressed over the years. Does this sound right for the magnum? I can't remember back to when it was new.
Old Aug 29, 2009 | 11:57 AM
Yes they wear over a period of time and slack will happen,replacement bushings aren't that expensive and can be done at home.
Old Aug 29, 2009 | 07:27 PM
Yep, you confirmed what I was thiking. Should the spacers be replaced while I got it apart or can they be reused. I will have to double check, but I'm thinking they were steel.
Old Aug 29, 2009 | 11:21 PM
Wenty's Avatar
They should be brass spacers. New bushings and you should be good to go, spacers should be fine...they're cheap and easy to replace. I think you can get better bushings from HPD for your machine as well.
Customer Service #1
May 15, 2020 08:46 AM
Todd C Wadas
2) Chassis problems..
Sep 23, 2015 11:31 PM
MikeyBoyesq
Sep 22, 2015 10:02 AM
Alex G.
Sep 19, 2015 06:34 PM
cdstang
Aug 31, 2015 07:52 AM
