Need help w/ sportsman 500
Old Aug 29, 2009 | 10:22 PM
blastin45s's Avatar
Default Need help w/ sportsman 500
I bought a used SPORTSMAN 500 at the beginning of summer, still havent ridden it. It is very hard to start, to the point of flooding every time. It may start 1 out of 20 times. I have replaced coil, put in a NGK IRIDIUM plug, removed carb and cleaned it, checked float,
blew compressed air thru all ports. Still, hard to no starting. Any help will be greatly app.
Old Aug 29, 2009 | 11:38 PM
switzomatic's Avatar
Default Help
Might need a valve adjustment and compression check.
Old Aug 30, 2009 | 12:58 AM
HeftyLefty's Avatar
Also check the gap on the ignition coil pickup.
Old Aug 30, 2009 | 07:10 AM
stendori's Avatar
Super Quad Patrol
I'm watching you!
what year bike is it? just wondering if its the older ones w/ a bad cam.
Old Aug 30, 2009 | 02:26 PM
blastin45s's Avatar
Old Aug 30, 2009 | 02:32 PM
blastin45s's Avatar
I put a aftermarket coil on, how do you check the gap, are the valves hard to adjust?
When it runs, it does not smoke at all. As far as the compression, when I try to start it w/ pull rope, it is hard to pull, does that mean the compression is up to par? Once I get it started it will start every time untill it cools off. Thanks 2 everyone for their help.
Old Sep 1, 2009 | 06:43 PM
Rickeyparker's Avatar
It could have a sheered woodruff key on the flywheel, this will cause the same problem.
Jmuddin284
Jan 19, 2026 07:16 AM
chingchangchong
Aug 7, 2022 11:36 AM
slowgsxr97
Sep 8, 2015 07:33 PM
Pahuntman
Sep 5, 2015 11:07 AM
cdstang
Aug 31, 2015 07:52 AM
