2003 Scrambler 500 PLEASE HELP!!!!!
Old Sep 2, 2009 | 05:42 PM
scaboney's Avatar
Default 2003 Scrambler 500 PLEASE HELP!!!!!
I am having some issueswith my scrambler......i ride it perfect for about 15-20 minutes then all of a sudden it backfires then stalls out on me....during this period i can tell the engine is hotter then usual but the radiator light never comes on....i try using the ignition to start it but it doesnt work...i try pulling the starter and that dosnt work....once it has sat for about 10 minutes i can use the ignition start and fires up fine but still runs hot....it has done this twice now.....The scrambler is in mint condition and has never had a problem...Please some one help me
Old Sep 2, 2009 | 07:46 PM
eggenz7's Avatar
have you checked the water lately? what about the oil?
Old Sep 2, 2009 | 08:43 PM
ftwflh's Avatar
First try the simple stuff like when it acts up take the gas cap off and see if it will start
Old Sep 3, 2009 | 01:32 PM
scaboney's Avatar
Default still not working
i put some old gasoline in i when it was on empty.....right after i did this it started acting up.....could this be the problem?........I really ned help here guys
Old Sep 3, 2009 | 01:33 PM
scaboney's Avatar
Exclamation water and oil
water seemed fine but oil needed to be changed ...i just did that today and will give it a ride today...hopefully that is the solution.......
Old Sep 3, 2009 | 05:18 PM
ftwflh's Avatar
drain the gas out of the carb and tank and fill up with fresh gas
Old Sep 3, 2009 | 05:26 PM
bholmes's Avatar
Sounds similar to when my bro's CDI box crapped it's self on his LTZ400, but it would only do the no-start for 10 minutes deal after you shut it down. But that sounds kinda electricalish to me. But before you go on a gremlin hunt I'd definitely try changing the gas also if it does the no-start deal, while you're waiting your 10min before it'll run again pull the plug and see if ya have fire.
exmotocrosser
Sep 13, 2019 06:12 AM
Matt123
Sep 29, 2015 01:29 AM
exmotocrosser
Sep 26, 2015 08:18 AM
Nosparkpolaris
Sep 20, 2015 04:21 PM
Hw00d
Sep 10, 2015 08:53 AM
