NEW OWNER....NEED INfO
Old Sep 7, 2009 | 11:44 AM
A_GR__N69's Avatar
Default NEW OWNER....NEED INfO
Rear axle bearings going out. First question will a new swing arm fix this problem? Second question.....will a 2005 DS 650 BAJA X swing arm match up will a 2002 DS 650 BAJA swing arm? Also i have alot of back firing going on when decelerating...I do have a BIG GUN QUITE SERIES EXHAUST but this is BACKFIRING i don't think it the normal way its suppose to sound. Any help would be appreciated on any of these questions. Also some1 told me to get moroso to beef up my octane rating....any1 heard of this?
THANKS I'm sure I'll have alot more to ask
Old Sep 7, 2009 | 12:01 PM
95wolv's Avatar
Unless your swing arm is shot, why not just put new bearings in the axle carrier? putting a used one in probably has used bearings, so you may need to fix that as well. The backfiring on decel is common with aftermarket exhausts, you are a little lean on the idle circuit, try opening up the mix screw a 1/4 turn at a time until it goes away. If you have to go over 3.5 turns to get it to stop, you may need to go up one size on the pilot jet, then start at 1.5 to 2.5 turns out and see how that goes. If you are lean on the idle, you should check your plug after a good run to see if you are lean on the top end, may need to jet up your main as well.
Old Sep 7, 2009 | 10:53 PM
Big Ray 800's Avatar
Has a DS 800 Turbo Nitrous EFI money eating monster!
check your exhaust header pipe if its loose it will backfire on decel
buddieboy
Dec 9, 2016 05:50 PM
exmotocrosser
Sep 26, 2015 08:18 AM
woodthings
Sep 25, 2015 05:58 PM
Todd C Wadas
2) Chassis problems..
Sep 23, 2015 11:31 PM
greg86hd
Sep 16, 2015 12:32 AM
