Recon, high idle when warm
Old Sep 8, 2009 | 03:36 PM
Budgood's Avatar
Default Recon, high idle when warm
My 2000 Recon idles fine when its cold,
but after it is warmed up its idling high.
Any suggestions?
Old Sep 10, 2009 | 10:34 PM
cherokee99's Avatar
it is possible that your pilot skrew is a little lean and after the engine warms up this problem shows itself.
here is what i would do. 1. inspect and tighten carb boots, so there is no air leak.
2. service your exhaust, there is a bolt on the bottom of the exhaust can. plug the exhaust hole with a rag and remove the bolt, then rev the quad a few times until black carbon stops coming out.
3. wait for the high idol to take effect then tune it down with your idol speed screw. that is how the manual says to set your idol. if this effects your cold starting ability then you may need to set your pilot screw richer(screw out 1/2 turn at a time).
a good carb cleaning wouldn't hurt ether.
Old Sep 11, 2009 | 12:46 AM
JeffinTD's Avatar
I believe your carb uses an enricher instead of a choke. It could be hanging up, basically stuck on.
Zach509
Sport Quads
Aug 3, 2015 02:44 PM
willday08111217@gmail.com
Technical and How-To Articles
Aug 1, 2015 04:05 AM
binky79
Jul 30, 2015 06:37 PM
ranvette
Jul 12, 2015 06:34 AM
MNatv89
Jul 7, 2015 11:36 AM
