just picked up a trailblaser with a 500cc in it
Old Sep 9, 2009 | 11:03 PM
sender's Avatar
Default just picked up a trailblaser with a 500cc in it
I just bought a trailblaser and the previous owner swapped a 500cc into it. Anyone have any idea what the engine could be from?
Old Sep 10, 2009 | 06:34 AM
eggenz7's Avatar
probably a scrambler 500.
Old Sep 10, 2009 | 07:16 AM
drlang's Avatar
There should be a date code and serial # on the pull start. Check with a dealer. Doc
Old Sep 10, 2009 | 08:36 PM
sender's Avatar
awesome good to know! Took it for a little rip today and man it is fast! Needs to have a little maintance work on it though thats for sure. I noticed that the handle bars are a little to the left while going straight is there an easy way to fix that?
Old Sep 10, 2009 | 08:39 PM
sender's Avatar
oh yeh! and also the back foot break wasnt working
Old Sep 10, 2009 | 09:20 PM
carlobee's Avatar
wow. i really don't know about that one. i can't seem to figure out why even the foot break isn't working.
Old Sep 11, 2009 | 02:37 AM
popoman's Avatar
the rear brake, is it mechanical or is it hydraulic? the hydraulic will have a brake hose running from it to a caliper. Mechanical will have linkage that goes to the caliper and will hook up to a arm/lever. My 94 sportsman 400 is mechanical my 05 sportsman 800 is hydraulic.
If it is hydraulic it is either worn out seals or it merely needs to be bled because it has air in it. Easy to bleed... pump and hold the foot pedal and open the bleeder valve. When you feel the pedal bottom near the floor board close the valve so it doesnt suck air in. Make sure to keep the fluid topped off and repeat procedure until you see no air bubbles coming out.
If it is mechanical there is an adjustment in the bolt where the arm attaches. You loosen the lock nut screw in the bolt then tighten down the lock nut. Make sure the linkage is actually attached if mechanical as they can come off if not properly put in place with a cotter pin.
Old Sep 11, 2009 | 05:58 AM
ftwflh's Avatar
the GENIII rear brake pedal is a joke.You can bleed it but do so with the lid off and it will work for a ride or 2.It is basicly an auxiliary brake.It will still work off the hand brake.
Old Sep 11, 2009 | 07:44 AM
scootergptx's Avatar
Supersock
Hired Gun!
They should just call the rear brake the exercise pedal.
Joe454
Nov 20, 2020 01:19 PM
EIF
Apr 20, 2017 07:15 PM
Whitelx1
Oct 2, 2015 10:55 PM
cboler9
Sep 24, 2015 08:35 PM
mywifesquad
8
Sep 21, 2015 08:20 AM
