1986 trx 350 parts comp
I am looking at a 86 350 4x4 will parts from 87-89 bolt on mainly front end seed alot of parts on e-bay but most are for 88 or better they look the same but may not be any body know
These 2 change's were only made to the 1989 Honda TRX350FM Foreman 4x4 , the 1986 to 1989 Honda TRX350D 4x4's only change was the optional removeable handlebar headlight for use as a spotlight ; everything else were the same spec's hope this help's !
williebee..........
Thanks for post I did check out bike bandit and the cv axle part numbers were similler but slightly differant. Not sure if the bike needs axles or not. I have not looked at it yet but the guy said the front end was wore out. but i do not know if that was cv axles or the ball joints.
Sorry to resurrect this thread, but wanted to add my 2 pennies. I have an 86 that I've been rebuilding and just wanted to warn against assuming many of the parts are the same. There are a lot of subtle differences between the 86, and the 87-89 fourtrax.
I bought a starter gear set on ebay that even was listed as from an 86, and it didn't fit. It was from an 87.
If you get a service manual it will show the difference between the years, or look at bikebandit like someone else mentioned.
1986Vmax540
Jul 9, 2021 09:53 PM
National Motorsports
Aug 7, 2015 09:41 AM
