1986 trx 350 parts comp
Old Sep 11, 2009 | 06:57 AM
bigblue89's Avatar
Default 1986 trx 350 parts comp
I am looking at a 86 350 4x4 will parts from 87-89 bolt on mainly front end seed alot of parts on e-bay but most are for 88 or better they look the same but may not be any body know
Old Sep 11, 2009 | 12:43 PM
Williebee's Avatar
Post 1986 trx 350 parts comp
I would say yes parts should fit from 86' to 89' there wasn't any major change in design of these quads , at least there wasn't any change in my 1986 Honda TRX350FM Foreman 4x4 in the plastic's ; the only change Honda made for my Foreman 4x4 were larger tire size (25x10x11's front and rear on 86' model to 25x8x12's front / 25x10x12's rears on 89' model ) and the 1989 Honda TRX350FM Foreman had an extra low gear !
These 2 change's were only made to the 1989 Honda TRX350FM Foreman 4x4 , the 1986 to 1989 Honda TRX350D 4x4's only change was the optional removeable handlebar headlight for use as a spotlight ; everything else were the same spec's hope this help's !
williebee..........
Old Sep 11, 2009 | 03:35 PM
no1's Avatar
no1
What I do is go to bike banit and find the part number for the part I want. Then I just compare the part numbers with the newer models. If the numbers match up it should fit.
Old Sep 12, 2009 | 10:45 AM
bigblue89's Avatar
Thanks for post I did check out bike bandit and the cv axle part numbers were similler but slightly differant. Not sure if the bike needs axles or not. I have not looked at it yet but the guy said the front end was wore out. but i do not know if that was cv axles or the ball joints.
Old Sep 12, 2009 | 06:26 PM
HondaMechanic's Avatar
Axles on 1986 are different size ..
Old Oct 5, 2009 | 02:03 PM
PainGiver's Avatar
Sorry to resurrect this thread, but wanted to add my 2 pennies. I have an 86 that I've been rebuilding and just wanted to warn against assuming many of the parts are the same. There are a lot of subtle differences between the 86, and the 87-89 fourtrax.
I bought a starter gear set on ebay that even was listed as from an 86, and it didn't fit. It was from an 87.
If you get a service manual it will show the difference between the years, or look at bikebandit like someone else mentioned.
Old Oct 5, 2009 | 02:30 PM
honda nation1's Avatar
hey just replyin cause i need 15 more replys
1986Vmax540
Jul 9, 2021 09:53 PM
National Motorsports
Aug 7, 2015 09:41 AM
Backwoods_badass
Aug 2, 2015 10:40 PM
JoAnnS
Jul 23, 2015 02:18 PM
