Bayou 220 electric start problems
Old Sep 16, 2009 | 12:06 PM
lawless's Avatar
Default Bayou 220 electric start problems
Have (2) 220s both with same problem - will not start using the starter switch. Both start fine using pull start and both start fine when I jump the solenoid.
I've troubleshot as much as I can - does anyone have any suggestions?
thanks,
Old Sep 18, 2009 | 01:28 AM
07bloomfieldb's Avatar
If they start fine with electric start when the solonoid is bypassed check two things.
1 When you press the starter switch do you see 12v at the switching post of the solonoid? If not investigate the ignition wiring.
2 If you're getting that, but no start, and if you put a screwdriver on top of the solonoid (across the two posts) it starts then you have a dud solonoid.
4xrider
Apr 10, 2017 01:36 PM
momofo
May 27, 2015 12:06 PM
rmx251
Sep 10, 2000 11:40 PM
mrdci
Feb 7, 2000 07:16 PM
mrdci
Dec 4, 1999 11:03 PM
