01-03 forman shift problems
Old Sep 21, 2009 | 08:53 AM
MTRFLEET's Avatar
Default 01-03 forman shift problems
I have a 02 forman rubicon that the shift display blinks all the time and won't shift out of low gear.can anyone help me?
Old Sep 21, 2009 | 09:36 AM
jwjahr's Avatar
unplug speedo behind radiator bothe wires and see if it will go into second if it does rplace speedo if not on left side of engine remove cover and there is a sensor unplug and clean connection if no good change that sensor
Old Sep 21, 2009 | 09:52 AM
MTRFLEET's Avatar
Thanks i will give that a try
Old Sep 21, 2009 | 10:26 AM
jwjahr's Avatar
with out speedo it should up shift but you will have to stop and restart to down shift
Old Sep 21, 2009 | 03:13 PM
HondaMechanic's Avatar
You have to count the flashes ..
Without speed sensor the ECM will go into failsafe mode giving you 1 low gear to safely drive back to your vehicle or home ..
Old Sep 22, 2009 | 11:10 AM
MTRFLEET's Avatar
It flashes all the time everything on the left side dones not show what gear you are in
heath legg
Jul 24, 2015 01:01 PM
hondarider1234
Jul 21, 2015 11:53 PM
KimSJoh
14
Jul 18, 2015 07:20 PM
Scottma518
Jul 16, 2015 09:19 PM
sara durrant
Jul 6, 2015 05:32 PM
