offset flywheel
in a dirtwheels they show tha you can rev your engine higher if you get a offset flywheel. do they make them for blaster's and if they do, where would i be able to get one. i heard they were pretty cheap, under 30
u can get an offset flywheel KEY from Vitos performance. it will advance ur timing 4 degrees.I have seen the dynos and it makes a pretty good bit of difference especially for the money. i recently bought one from them but found out that i had to run about 8 degrees advance for alcohol on my banshee so i have never used it. u can get it for about $25.00 from them. they usually have a full page ad in dirtwheels mag.
are they the only ones that sell them, does it already advance the timing by 4 percent or do you have to set it any way. i just have a pipe and reeds and will i have to do anything else to my quad if i put it on. thanks for the help
chingchangchong
Aug 7, 2022 11:36 AM
badgerboy1
Sep 26, 2017 06:11 PM
Scooter's Shop
23
Oct 22, 2015 07:04 PM
