recon problems
Old Sep 28, 2009 | 07:50 AM
redrecon99's Avatar
Default recon problems
okay so i got a recon this weekend. i traded a blown up blaster for it and the recon had some probs in the back end believed to be the u joint but im not to sure. when i start it the engine runs like a beaut btw. but i shift to first go to take off and she starts grinding opinions please? and also it needs its valves adjusted it has a slight tapping towards the top end no smoke coming out of the exhaust tho. also the drain plug for the oil is stripped is that able to be retapped or no? other then those problems the fourwheeler is in great shape i took it to the shop today to find out what is wrong with the backend then im buying the parts and fixing my self.
Old Sep 28, 2009 | 12:50 PM
faruquehabib's Avatar
welcome to the forums! the slight tapping at the top end leads me to believe it is related to the grinding when you first shift into gear. did the mechanic say what was wrong? maybe a new pumpkin?
Old Sep 28, 2009 | 03:18 PM
redrecon99's Avatar
the tapping stops when the engine gets warm. and im about to take her now.
Old Sep 28, 2009 | 10:32 PM
redrecon99's Avatar
update... the shop said the whole rear end is bad just by touching it and moving it around estimated cost of 700 bucks.. is this possible? what should i do i heard it could just be my rear final gear should i take it apart and try and see?
Old Sep 29, 2009 | 06:37 AM
budedm's Avatar
Well, if you're mechanical at all, take it apart. Go to DGY.com and look at an exploded view. Get a Honda service manual and Go for it. If it's already bad, what harm can you do?
Old Sep 29, 2009 | 08:56 AM
i concur. if you take it apart and its a mess and all looks bad, or you cant put it back together, just take it in! you have nothing to lose by trying yourself first except saving a few $$...
Old Oct 1, 2009 | 07:40 PM
zooooom's Avatar
What model is this recon? Reason I ask is my Dad's got a Foreman that stripped the splines on the axle that turns the ring gear. $100 and fixed it.
Old Oct 1, 2009 | 11:43 PM
carlobee's Avatar
Yes. I would agree with this one. Unless you are a mechanical and have a great experience in this, then you can do that by yourself.
Firefighter400
Oct 8, 2022 06:38 PM
greg74
Sep 10, 2019 03:03 PM
ogio117
Polaris Side by Sides
Apr 29, 2019 03:14 PM
hondarider1234
Jul 21, 2015 11:53 PM
MNatv89
Jul 7, 2015 11:36 AM
