2006 trx350fm transmission
Old Sep 28, 2009 | 12:28 PM
meyek4's Avatar
Default 2006 trx350fm transmission
my honda jumps out of gear; mainly in 4th and 5th, but sometimes in lower gears while climbing slopes. is this a clutch adjustment problem, bent shift rod or bent shifter shaft? it's rideable this way, just annoying because i have to keep shifting it back into gear when it jumps out!
Old Sep 28, 2009 | 12:54 PM
reconranger's Avatar
Red Rider
Honda, accept nothing less!
Jumps out of gear...does that mean into neutral, or into another gear or what???? Might be that the clutch is just slipping or worn out, and what feels like jumping out of gear is just a bad clutch.
It's easly to adjust the clutch, so do that first by all means. The procedure is in your owner's manual.
Old Sep 29, 2009 | 01:49 PM
meyek4's Avatar
i seems to go to neutral. click the shifter up and goes back into gear.
Jeff Roper
Feb 1, 2022 11:48 AM
r1pilot83
Utility ATVs
15
Nov 25, 2019 11:39 PM
akguy31
Aug 31, 2019 04:34 AM
r1pilot83
Sep 27, 2015 07:38 PM
WilliamBos
Sep 22, 2015 04:07 PM
