probs w/84 200s weak spark
Old Oct 2, 2009 | 03:51 PM
santbaker's Avatar
Default probs w/84 200s weak spark
Awhile back I was having trouble with the idle on my 84 200s. Figured it was a carb prob. Cleaned the carb, then it wouldn't start. I took it to a local place to have them check it out. Over a month later, they still hadn't checked it out, so I picked it up. Found a new carb for $30.00 so I installed it. Still won't start. It has a weak spark. What can I do to fix the spark prob. When I get that taken care of, I can find what the next prob will be.
Old Oct 4, 2009 | 09:02 PM
posty2100's Avatar
sounds like needs new CDI if the spark is weak
also check out 3WHeeLeR WoRLD FoRums - 3WHeeLeR WoRLD FoRums
best site in the world just post there or use the search tool and find posts similar to your problem
Old Oct 4, 2009 | 09:07 PM
HondaMechanic's Avatar
Here are the ignition tests for a 1984 ATC200S ..
Old Oct 17, 2009 | 03:55 PM
santbaker's Avatar
Thanks for your input. It worked. Finally got it to start and run. Will be taking it out for some fun now.
Old Oct 17, 2009 | 05:30 PM
Williebee's Avatar
Post probs w/84 200s weak spark
What was the problem with your 200s ? Was it the CDI / electrical problem or what ?
Your input on what you found the problem to be would a great help to others later on .
Thanks in advance santbaker , and thanks again to you HondaMechanic for the pages on trouble shooting electrical system ; you are truly a huge asset to the forums !
williebee..........
Old Oct 17, 2009 | 05:35 PM
santbaker's Avatar
Sorry. Yes it was the CDI. Got it new on ebay for $8.00. And yes, thank you HondaMechanic. The pages on electrical were easy to understand.
Old Oct 18, 2009 | 07:56 PM
Williebee's Avatar
Thanks for posting the fix for your 84 Honda 200s this will help others later on , and it's great to hear that you found a great price on the CDI ; new or used that's a great price !
Some time's a member will forget to post the info on the fix of their quad afterward's , so thank's again for posting the end result's ; this will make it easy for the next member who need's this info !
williebee.......
theddaug
Aug 15, 2015 09:17 AM
Hatrackr
1) Engine problems..
Aug 11, 2015 09:03 PM
toonces
Aug 5, 2015 05:55 PM
95wolv
Jul 17, 2015 08:13 PM
