better gearing for wheelies?
Old Oct 5, 2009 | 10:38 AM
cherokee99's Avatar
Default better gearing for wheelies?
i put stock size sprockets back on my 300ex last year. now it seems like i cant hold a wheelie, or even pull one, until im at pretty high revs in 1-2nd gear. clutch-less wheelies btw. would lower or higher gearing help me in this? also the gears seem to come really fast and close together,anyway to lengthen them out?
Old Oct 5, 2009 | 10:50 AM
reconranger's Avatar
Red Rider
Honda, accept nothing less!
I have always found that lower gearing helps with wheelies, becasue it gives you more torque. But...you will of course lose top end speed as a tradeoff.
On my 400EX for example, I went down one tooth in front, and it made it wheelie happy. Any time I would stab the throtle, the front end was off the ground...it was way to much! I finally settled on one tooth bigger in back as a good compromise. Improved tight trail riding, and makes controllabe wheelies easier.
As for as your internal gearing, not much you are going to be able to do about those...
Old Oct 15, 2009 | 08:20 PM
00 440ex's Avatar
Was that one tooth bigger in back with the one tooth smaller in front or did you change the front back to stock
Old Oct 15, 2009 | 11:08 PM
Red Rider
Front stock, and back 1 tooth bigger. I would maybe go 2 teeth, but it would be to big and rub on my skidplate.
Old Oct 17, 2009 | 10:58 PM
duster's Avatar
Drop a tooth in front to get more wheelie happy.
Add a tooth in front to get longer gear spacing.
There is no free lunch, much less having your cake and eating it too.
patrick.oc123
Sep 16, 2015 03:45 AM
patrick.oc123
Sep 15, 2015 02:45 PM
bigbear350quad
Sep 11, 2015 12:40 PM
John Reed
Sep 9, 2015 03:46 AM
awer1968
Sep 8, 2015 11:02 AM
