TRX300FW Rear Bearings
Old Oct 10, 2009 | 11:41 PM
dough1's Avatar
Default TRX300FW Rear Bearings
Has anyone changed the rear bearings in the final drive gear assembly of TRX300FW and where can I get the special tool required for the pinion gear?
Old Oct 11, 2009 | 05:56 AM
HondaMechanic's Avatar
There are 3 special tools for the rear differential .. Mine are from Honda and are quite expensive .. There maybe other campanies that make aftermarket ..
Old Oct 11, 2009 | 02:23 PM
k_902's Avatar
I just redid mine last month, for the pinion gear I found a nut that fit and used a big socket to get it torqued. I think the nut was from a 2" ball or something...
Removing and replacing the bearings are pretty straight forward though the pinion needle bearing can be a pain.
If your worried, I'm sure a local dealer will have the tools to help you out. 10 mins worth of labor to torque everything down for you that requires the special tools.
Old Oct 11, 2009 | 08:08 PM
dough1's Avatar
thanks, I'll try my local dealer first.
Ean
Dec 19, 2022 08:48 AM
STLyamwar
Jul 25, 2020 04:44 AM
Polaris5
Aug 29, 2015 09:11 PM
Peter_
Jul 18, 2015 07:06 AM
rcappie4
Jul 10, 2015 04:54 PM
