Good and bad about Honda 400ex
Old Oct 20, 2009 | 05:21 PM
4wheelerRider's Avatar
Default Good and bad about Honda 400ex
I really like honda's atvs. I 've looked at 250x, 300ex, and 400ex. Whats good and bad about the 400ex?? I want to buy a 400ex that is a 2005 or newer because of the reverse. I ride trails and thats it. I dont race. How good of a trail quad is the 400ex?? Also if you live near southern maine and you have a 400ex for sale tell me. I might be interested if the price is right (probuly won't spend over $2000) Thanks
Old Oct 20, 2009 | 05:28 PM
reconranger's Avatar
Red Rider
Honda, accept nothing less!
Best tight trail quad on the planet (along with its little brother the 300EX)! This is a great machine that will run forever with just basic maintenance. Solid, basic, trouble free old school air cooled engine. Mine is an 00 that runs as good as the day it was new!
The only negative is that it is the slowest of the performance quads, but some simple aftermarket mods like vent the airbox and an aftermarket header and exhaust, can perk it up a fair bit however. I ride my EX almost exclusively in the local mountains, which is mostly tight woods trails. I rarely get out of 3rd gear, so who cares?
The other good trail quads are the Z400 and the Raptor 700. I like the Z for faster open trails and wide open country, and I don't like the Raptor much at all.
Old Oct 20, 2009 | 05:36 PM
thanks for the info recon. I was wondering if you wish your 400ex had reverse or if it is just easier to push it???
Old Oct 21, 2009 | 08:05 AM
Koopa's Avatar
Is addicted to 4 wheel'n!
Occasionally wish I had reverse. It don't take long before you learn what to watch for and find ways of working around the fact. I wouldn't let it let you pass up a good deal.
As far as problems the only thing I have seen to be a common issue on the 400EX is the wiring harness behind the headlights. It tends to get wore out and show wires leading to shorts. Every time I hit my brights it would pop a fuse under the seat. My buddies lights wouldn't work at all. Easy enough to fix but, it's something to check.
Old Oct 21, 2009 | 08:08 AM
Red Rider
For what I ride (no mud by the way....when it snows I ride the Rancher), reverse is a nice luxury but hardly a necessity.
Old Oct 21, 2009 | 08:12 AM
Red Rider
Ditto! This may have improved with later models that have different body work. We don't see these posts much anymore.
Only thing I have had to replace is the rear bearings. It was really my own fault, for riding in very fine silt in a flash flood. Some silt much have gotten past the seals, and toasted the bearings. Again, my own doing!
Old Jan 20, 2014 | 08:14 PM
Simon De Asian's Avatar
Default Re 400ex
dont they have subframe and a arm problem? are there main problems? are there any more and are they easy to fix?
Old Jan 28, 2014 | 04:44 PM
MarioWeldingInc's Avatar
i have an '03 400ex with no problems. no cracks on the sub frame, frame or arms. factory front shocks are horrible, you can get a set of 08 and up 450r shocks that bolt in with a 2 minute modification. night and day difference or get the factory ones revalved by GTT for about the same price. The axle nut tend to loosen up if not torqued properly and thread locker used. Quick fix. The automatic cam chain tensioner can go without warning. If you get a 400ex first thing I would do is replace the cam tensioner. Another easy fix that you can do without taking apart the engine. Also check the rear axle carrier bearings for noise... any quad with a SRA will need axle bearing eventually.
hoopduerr
Jun 2, 2015 09:01 AM
hoopduerr
Jun 1, 2015 08:22 PM
neilbedwell
May 29, 2015 02:24 PM
lovinhonda
Jan 25, 2000 09:17 PM
roktoy
Aug 25, 1999 04:37 PM
