03 250 2X4 - Only Has Ignition During 'Crank'
Old Oct 29, 2009 | 05:45 AM
BigBadStang's Avatar
Default 03 250 2X4 - Only Has Ignition During 'Crank'
I've got an 03 250 that will only stay running if you hold down the starter button. As soon as you release the start button, it dies. I have looked over the wiring harness all the way from the battery to the key switch and starter button, and there are no signs of severed/chewed wires, and all the connections are intact. The only thing I saw was the little ground wire that comes off the main ground cable at the engine, and connects behind the air box above the vehicle information sticker looked like it had gotten hot (insulation cooked). The battery is bad, and I need to replace it. A bad battery wouldn't cause this would it? If anyone has a wiring diagram the could post up would help me try to find a starting point so I can isolate/diagnose the problem.
Thanks in advance.
Old Nov 10, 2009 | 10:43 PM
swampyjunior's Avatar
PM me an email address I have a pdf file of a wiring diagram for an 03 250 I can send you.
Also, does it pull start?
SJ
ultangler
Nov 30, 2024 01:35 AM
EIF
Apr 20, 2017 07:15 PM
Scooter's Shop
Oct 9, 2015 02:09 PM
kbazzy
Sep 26, 2015 11:26 AM
Sw00p
Sep 24, 2015 02:50 PM
