Proper way to check oil on 400EX?
Old Oct 31, 2009 | 12:45 PM
Kerick's Avatar
Default Proper way to check oil on 400EX?
My ex burns a little bit of oil, nothing major. So I need to check the oil more than ussual. But I was wondering what the right way to check it is. When its cold it reads almost half and when I warm it its higher. Shoul I check it cold/hot? When its hot do i wipe it on a rag and check again because when i do tht it reads none...
Old Oct 31, 2009 | 04:14 PM
reconranger's Avatar
Red Rider
Honda, accept nothing less!
Doing this wrong can have consequences! By buddy checked his wife's cold and overfilled it. Just before she took off, I saw a big puddle of oil below the quad. Luckily I grabbed her before she got away. The pressure from all that extra oil with nowhere to go, blew the lines right off the tank!!! Had she gotten away from me, she would have destroyed the engine....
The oil in these dry sump engines goes and hides somewhere while they sit. If you check it cold, like you said, it will read low. Assuming you know there is at least a reasonable amount of oil in there, you must start it up for a few minutes (better yet, take it for a short ride!), then let it sit for 5 minutes before checking the oil level.
Reactant
Mar 30, 2022 02:08 AM
metal249
Jul 28, 2015 09:35 AM
metal249
Jul 24, 2015 01:00 PM
95wolv
Jul 21, 2015 12:25 PM
KimSJoh
14
Jul 18, 2015 07:20 PM
