Technical and How-To Articles Post your Tech Tips and How-to articles here. Photo illustrations welcome
Ranch stuck in gear, Wrong about # of flashes
Old Oct 31, 2009 | 01:23 PM
jearlc's Avatar
Default Ranch stuck in gear, Wrong about # of flashes
This is a redo of my post about my 05 rancher that is stuck in 1st gear. the display is flashing 5 times not 3 like i said in the first post ! Sorry, Thanks again for any help .....
Old Nov 18, 2009 | 10:21 PM
atvhobby's Avatar
Default have you tried to manually switch gears
there is a wrench in your box for manual gear shifting. and what on the display is flashing the gear indicator number or the whole screen. is your battery dying? need more info
Old Nov 19, 2009 | 08:14 AM
jearlc's Avatar
Default Thanks for reply !
Hey man, thanks for replying. This is a rancher AT so it has no manual shift lever . I should have given more info in my thread ! I have since found that it was the angle sensor that was the problem . I have the new part but haven't been able to install because i hurt my back trying to start a chain saw, not a honda HA, ! Again , Thanks for the reply!
Old Nov 19, 2009 | 12:48 PM
atvhobby's Avatar
Default mmm
my 06 rancher es has a backup wrench to shift the gears manually. if the battery dies how would you switch gears? mabye u dont know about it, but mine is located spark plug side below the engine next to a mount bolt. there is a wrench for it in the box. im just wondering because how would you get the thing in neutral if its all elecronic trans.
Old Nov 20, 2009 | 06:49 AM
jearlc's Avatar
Default Rancher stuck !
The Rancher AT is either full auto or manual shift with the rocker switches on the handlebars. it has a forward, neutral, and reverse lever on the left side of the gas tank . It's my understanding that Honda doesn't make the Rancher AT anymore because of so many problems with the electrics,trans, etc.. Have a good one.
Old Nov 25, 2009 | 03:17 PM
swampyjunior's Avatar
Sometimes you can fool the angle sensor by shifting it into neutral manually with "the wrench" Or in my case a small pair of vice grips that I lock onto the shift post on the right rear side of the engine if you are sitting on it.
As mantioned a bad battery can cause it to stick in gear. The machine I I fixed always did it if you shut it off in gear and then tried to shift it to neutral to start it up again. We initally fixed the problem by only shutting it off in neutral. Then it got worse so we replaced the battery (which was cheaper and easier than the angle sensor). Have not had to do the angle sensor "YET".
SJ
ltrmc02
Jul 22, 2015 04:50 AM
micheleLeigh
Jul 19, 2015 07:32 AM
KimSJoh
14
Jul 18, 2015 07:20 PM
ghost civic
Jul 15, 2015 10:48 PM
sara durrant
Jul 6, 2015 05:32 PM
