Polaris Sportsman Exaust
Old Nov 17, 2009 | 07:38 PM
polaris man with issues's Avatar
Default Polaris Sportsman Exaust
How does a 05 polaris sportsman 500 ho sound like with out the exaust? Alwats wanted to know but didnt want to mess with exaust. I think my quad sound really stupid. There is no rumble at all. it sounds stupid. My brother has a brute force and a arctic cat and they sound awesome. Is there anything i could do except buy exaust to make it sound good? Just a rumble not like the anoying raceing quads
Old Nov 17, 2009 | 08:00 PM
readymixer169's Avatar
Of all the things I've lost in life, I think I miss my mind the most!
I've had my muffler off before while doing some work and tried it out just to see and it sounds. Really good! Although I would'nt run it that way all the time unless your going to rejet and other mods. If you open up the exuast your going to lean it out a bit and might want to consider other mods. Just my opinion.
Old Nov 18, 2009 | 08:45 AM
EPIChad's Avatar
On my 2000 500 Sportsman i took off the muffler when do some work. I wanted to know what it sounded like and holy crap was it loud. I couldn't believe that a machine that ran so quiet would be that loud. It sounded bad *** for a few minutes but wouldn't want to run it that way. You normally need some type of back pressure/muffler to make the engine perform its best.
Old Nov 18, 2009 | 04:02 PM
700 sportsman's Avatar
You could try glass packs if you don't want to spend the money on a full exhaust, they are fairly cheap and sound pretty good, there's some clips on youtube
Old Nov 19, 2009 | 04:10 AM
4getful2's Avatar
you could go to a farm&home supply and get a larger garden tractor muffler with a straight thru design($25-$30) but you'll need to modify the inlet and make some hangers
Old Nov 25, 2009 | 06:13 AM
Devoman's Avatar
Default Muffler Mod
I cutoff the elbows, cut bigger hole in muffler and welded 1 1/2" dia stainless elbows on mine. sounds alot better and has more power.
06 sportsman 800
Old Apr 26, 2015 | 10:46 PM
ronnieman69's Avatar
Default 2015 polaris etx
06 sportsman 800
I'm doing the same thing to my new etx. But I stuck a prybar down the inlet tube and opens the holes in the front baffle a little bit more. Can't wait to see how it works out. Want a little more flow and power but don't want it loud.
Jmuddin284
Jan 19, 2026 07:16 AM
Gtsordo
Jul 13, 2015 10:38 PM
Shifts
14
Jul 13, 2015 08:41 AM
bzdok1234
Utility ATVs
Jul 3, 2015 05:32 PM
Shifts
Jul 3, 2015 07:59 AM
