Timing a 300ex
Old Feb 24, 2001 | 12:29 AM
94DGblaster's Avatar
ok ok..i got this much
you move it to top dead center, on what stroke?
And just how do i know i am on this stroke?
my dad was asking that..
and i was thinking why the hell does it matter!
you are setting the timing..so if the piston is at top dead center..and the cam is at the straight up and down position..its going to set it up right..because it isn't on a certain stroke, the stroke is decided by the cam?
the cam is going to do it in the right order?
This is what i don't understand...!!! come on..someone help me
Old Feb 24, 2001 | 02:49 AM
jmann440's Avatar
on the compression stroke...valves closed...there should be slack in your rocker arms...if your on the exhaust stroke,your exhaust valve will be open and intake closed......hope that helps
Old Feb 24, 2001 | 08:35 AM
what i just figured out..
i am going to be on a permanent compression stroke because the valves are always going to be closed. So if i look at the fly wheel..there is a TDC mark correct? So i am going to be on the compression stroke TDC no matter what..!!
Old Feb 24, 2001 | 09:36 PM
Mike300ex's Avatar
Aaron what exactly are you trying to do? Put your motor back together? and setting the cam/crank timing?
Basically as long as you set the crank at the tdc mark and the cam is set at the right mark you are all set. The cam is what actually decides on what stroke you are on. As long as the cam is set right and the crank is in the right postion it doesn't matter.
Mike
Old Feb 25, 2001 | 08:53 AM
thank you, that is what i thought. But my dad started giving me all this crap about how i was thinking all wrong!
I knew i was right, lol
Old Jun 29, 2004 | 09:57 PM
CRF230rider's Avatar
Default Timing a 300ex
there are three marks on the flywheel which one should i use there is one with a "T" one with a "F" and the other is just two marks close togther and which mark should i use on the camshaft gear
Sjrpp
May 2, 2023 03:59 PM
slowgsxr97
Mar 18, 2022 03:40 AM
Sjrpp
Nov 15, 2019 09:59 PM
Sjrpp
Jun 2, 2019 07:25 AM
95wolv
Jul 17, 2015 08:13 PM
