help 2000 trailboss
Old Nov 24, 2009 | 06:08 PM
blaster24's Avatar
Default help 2000 trailboss
bike had been missing real bad got in garage and changed the plug old plug was black and sooty pulled air box cover off and it had almost a quart of gasoline in it! Anyone know what would cause this? Thanks alot
Old Nov 24, 2009 | 07:39 PM
ftwflh's Avatar
Check valve settings.Should be .006 then take carb apart clean both jets good replace needle and seat and check float height
Old Nov 24, 2009 | 07:55 PM
blaster24's Avatar
Do you know what the float height is supposed to be? Thanks ftwflh appreciate the help!
Old Nov 24, 2009 | 09:10 PM
ftwflh's Avatar
check a manual on that one
Old Nov 26, 2009 | 03:37 PM
blaster24's Avatar
Got it fixed last night! Was the needle valve and seat replaced both and a new seal cleaned all the jets and she is running like she used too! Thanks for the help ftwflh!
Old Nov 26, 2009 | 04:42 PM
ftwflh's Avatar
You are welcome
Old Nov 27, 2009 | 07:20 AM
Kerbbirds's Avatar
Turn the gas off when not in use and the needle and seat will last.
Old Nov 27, 2009 | 08:00 AM
blaster24's Avatar
Kerbbirds i almost always do but may forget once in awhile. Ran great for 8yrs this is first real problem with the bike! I keep the oil and filter changed plug air filter fuel filter etc. Has been a great bike! Also adjusted valves ftwflh thanks again!
Gwolf228
Feb 18, 2017 01:36 AM
Dammar
Apr 20, 2016 06:03 AM
Scooter's Shop
Oct 9, 2015 02:09 PM
MeadowlarkFarm
Sep 9, 2015 03:08 AM
Myronh
Sep 8, 2015 11:27 AM
