'07 Sportsman-NO LIGHTS
Old Dec 7, 2009 | 06:58 PM
Wrestlerh171's Avatar
Default '07 Sportsman-NO LIGHTS
I have an 07 500 sportsman and went out huntin the other day and got back on it to go home after dark and it wouldn't start in gear and none of the lights worked(headlights, tail or brake lights and the work lights). I've checked for fuses everywhere but can't find any and the book helps me none. It would be much appreciated if someone could help get me going in the right direction!!
Old Dec 9, 2009 | 08:37 AM
caperinmuskoka's Avatar
Ride like you own it, Not like it's stolen!
Will the Quad start without the light switch in the "ON" position?
If the answer is YES...........Bad Sure Power Module Box...(ECM)..........
Oh..As for the fuses on the 2006 there are build into the ECM.......To reset you just turn the key switch to OFF and wait a few seconds and turn back on again.......Solid State circuit Breakers internally......Hope that helps........
..........Caper.......
Old Dec 9, 2009 | 08:47 AM
Yea it will start w the light switch off, so the ECM is expensive, the warranty covered one about the 3rd month I had it. Oh well it's always something! Thanks for the help.
Old Dec 10, 2009 | 08:57 AM
Not sure about cost in the U.S. States.........I am from Canada.........It was about 149.99 plus TAX here..........Get the dealer to run your VIN number.........I am on my third one and all were covered for me.........It will depend on your dealer.........(mine was great)....................NOT Polaris....Good luck .......
If you replace it yourself..Make sure you use the Dielectric Grease pack with the new one.....This will keep moisture out of the connections..........Caper............
95wolv
Sep 27, 2024 12:00 PM
wendal
Sep 7, 2019 06:46 AM
hueby
Nov 6, 2015 11:34 AM
panicmanic
Sep 28, 2015 12:59 PM
Alex G.
Sep 16, 2015 12:13 PM
