'07 Sportsman-NO LIGHTS
I have an 07 500 sportsman and went out huntin the other day and got back on it to go home after dark and it wouldn't start in gear and none of the lights worked(headlights, tail or brake lights and the work lights). I've checked for fuses everywhere but can't find any and the book helps me none. It would be much appreciated if someone could help get me going in the right direction!!
Will the Quad start without the light switch in the "ON" position?
If the answer is YES...........Bad Sure Power Module Box...(ECM)..........
Oh..As for the fuses on the 2006 there are build into the ECM.......To reset you just turn the key switch to OFF and wait a few seconds and turn back on again.......Solid State circuit Breakers internally......Hope that helps........
..........Caper.......
Not sure about cost in the U.S. States.........I am from Canada.........It was about 149.99 plus TAX here..........Get the dealer to run your VIN number.........I am on my third one and all were covered for me.........It will depend on your dealer.........(mine was great)....................NOT Polaris....Good luck .......
If you replace it yourself..Make sure you use the Dielectric Grease pack with the new one.....This will keep moisture out of the connections..........Caper............
