Shaky front end
Old Feb 24, 2001 | 11:38 PM
txtrailboss's Avatar
Buddy of mine has a 93 350 2 stroke 4x4 Polaris. The handlebars go crazy at about 30-35 mph. There is severe side to side "wobbling" through the handlebars at this speed. We replaced the A-arm bushings and tightened the lower end of the handlebar shaft (?technical term?) hoping that would fix the prob, but no luck so far. What should we be checking next? Any advice is much appreciated.
Thanks
Old Feb 24, 2001 | 11:45 PM
Blazer308's Avatar
Have You Tried Replacing The Tie Rod Ends. That Could Be Your Problem If There Is To Much Play In Them. Good Luck! 99 TB With Clutch Kit And K&N Filter
Old Feb 24, 2001 | 11:48 PM
The machine is surprisingly well maintained, and we have worked on everything we could make shake loose with it sitting still. How do you like your TB?
Old Feb 25, 2001 | 01:20 AM
Sportsman6x6's Avatar
This may sound pretty stupid but, have you checked the air pressure in the tires?? My friend had an old 250 4x4, it shaked just like you stated in your post. Comes to find out he had like 40 in one tire and 30 in the other, then 25 in one of the rears and 30 in the other.
Old Feb 25, 2001 | 11:24 PM
Farmr123's Avatar
Two more things come to mind. Wheel bearings and toe out. If the tie rod ends are tight, maybe you have a bad wheel bearing. If not, check the toe - out. The proper toe-out should be in the owners manual.
One last possibility could be tire sealant that has dried in the tires over time, and making them way out of balance. See if there is a 'heavy' spot in the tire by jacking up the front end & spinning each wheel.
Old Feb 25, 2001 | 11:25 PM
Farmr123's Avatar
Old Feb 26, 2001 | 02:09 AM
I do know that the toe is wrong, the bottoms of the tires are closer together than the top and the tires are worn accordingly (dont know if that's toe in or out) and this needs to be adjusted. I'll try that out in the morning. Thanks
STLyamwar
Jul 25, 2020 04:44 AM
toonces
Aug 6, 2015 10:46 AM
toonces
Aug 5, 2015 05:55 PM
carolinabomb
Jul 26, 2015 08:40 AM
tporath
Jul 11, 2015 12:31 PM
