05' sportsman electrical problem?
Old Dec 20, 2009 | 12:17 PM
tibb79's Avatar
Default 05' sportsman electrical problem?
Once I exceed 2200 rpm the battery light and speedometer needle start flashing and if I give it anymore throttle it just dies. Will not restart until key is turned off then back on. Then it fires right up and does it all again. I took it in to the dealer and they replaced the ECM on a recall and figured it was the voltage regulator contained in that. Still have the problem. They said they load tested the battery and it was ok. I'm stumped
Old Dec 20, 2009 | 12:29 PM
UP Rider's Avatar
tibb79,
I am also having an issue with my 05 500sp. When i hit deeper water it will sometimes go into stutter mode and i get a hot light. Had the ecm changed a couple of years ago on the recall, this problem just started.
Old Dec 22, 2009 | 09:12 PM
caperinmuskoka's Avatar
Ride like you own it, Not like it's stolen!
If you need to shut the Quad off and turn it back on to reset.....then this is still a issue with the Recall(Sure Power Module)
I am on my third one ,so just because the recall was done ,Don't think it can't fail again........I needed my Replacement REPLACED.......LOL...LOL......
Caper.........
Note:
When you turn the Quad off and back on there are Solid State Circuit Breakers inside the Module that are there for protection and this is how they are reset........
ripperray
Oct 10, 2023 02:42 AM
skittero
35
Mar 1, 2019 12:39 AM
Raccar1
Jun 18, 2015 02:17 AM
DOAinNY
Jun 11, 2015 10:34 PM
