Fuel it leaks out from the bottom of the carb
Old Dec 23, 2009 | 04:15 AM
linksprocket's Avatar
Default Fuel it leaks out from the bottom of the carb
Hi I have a Loncin 50cc quad.
Every time I fill it with fuel it leaks out from the bottom of the carb from a small pipe?
Any ideas on how to fix this please?
Old Dec 23, 2009 | 07:38 AM
OneTenCC's Avatar
Just a guess, but it sounds like a stuck float overflowing out the bowl vent. The carb will probably have to come off for a good cleaning.
Old Dec 23, 2009 | 09:41 AM
LynnEdwards's Avatar
Electrical Expert
I agree completely with OneTenCC.
Once you fix the carb make sure you have a fuel filter installed between the tank and the carb to keep this from happening again.
Also check your engine oil to make sure gas hasn't also leaked into the cylinder, past the rings and into the crankcase. Smell the dipstick. If it smells like gas then change the oil, run the engine, and change the oil again.
Old Dec 23, 2009 | 09:48 AM
Electrical Expert
Check out this link for a basic tutorial on how these type of carbs work:
YouTube - how motorcycle and atv carbs work
Old Dec 23, 2009 | 06:07 PM
mywifesquad's Avatar
KTM Patrol
Former Chinese POW!
Welcome to the forum linksprocket!
I would clean the carb and install a fuel filter..
Old Dec 24, 2009 | 11:52 AM
OneTenCC's Avatar
I always thought that vent was a neat idea as opposed to what small outdoor power equipment engines have (no external bowl vent). If the float sticks on those, it just fills cylinder/crankcase until there's no more room in the Inn.
Joel
rcappie4
Jul 10, 2015 04:54 PM
Robbbb55
CAN-AM (BRP) Ask an Expert!
Jul 8, 2015 02:16 PM
Robbbb55
Jul 8, 2015 02:11 PM
J-Mack
Polaris Side by Sides
Jul 4, 2015 04:19 PM
Mikea1978
Jul 4, 2015 12:37 PM
