wont stay running?
Old Dec 30, 2009 | 10:57 PM
asdfgh1's Avatar
Default wont stay running?
hi i maid a home maid chopper and it has a 49cc 2 stroke engine on it and it will not stay running its getting fuel spark and has plenty of compression it starts but wont stay running for not even 5 seconds. i used a smaller 2 stroke engine and its getting fuel spark and every thing and it runs just fine. ima using the same carb same plug same fuel and every thing why wont the 49cc stay running? any help will be appriciated thanks
Old Dec 31, 2009 | 12:01 AM
Doctorturbo's Avatar
GOT BOOST!
Check for a plugged exhaust pipe
Old Dec 31, 2009 | 05:27 PM
asdfgh1's Avatar
i did every thing is unclogged but the crank shaft is hard to turn and on the other motor the crank shaft turns fine so could that be a problem?
Old Apr 24, 2010 | 08:35 PM
Yummymummy's Avatar
Been having the same problem and took apart the carb 3 times, cleaned it, you name it, checked everything. Then a buddy told me he had the same problem and it was the needle in the carb sticking. It allows the carb bowl to fill up and then empty but then doesnt drop to allow refill. He said to just buy a new carb, they are about $30 cnd if you can find one. Don't quote me tho, I havent tried that yet. Im gonna try cleaning the needle 1st, then buy a new one if I have to.
Good luck & keep us posted
whitty
67
Feb 24, 2021 02:52 PM
MikeyBoyesq
Nov 27, 2020 02:44 PM
Dame0927
Oct 29, 2015 10:13 PM
jayking232003
Jun 9, 2015 02:54 PM
blaze_master
May 26, 2015 11:18 AM
