hawkeye carb problem
Old Jan 2, 2010 | 08:36 PM
scobrother's Avatar
Default hawkeye carb problem
i am having trouble with this carb idleling like crazy when i touch the throttle. if i turn the idle set down the engine will start knocking. also the choke cable is stuck, you can't pull it. could that be the problem?
Old Jan 3, 2010 | 08:30 AM
Kerbbirds's Avatar
The cable maybe stuck because the carb is all gunked up inside, did the bike sit for a while , if so the carb needs a good cleaning and drain the gas out of tank and refill with fresh.
Old Jan 3, 2010 | 12:44 PM
Mongrol's Avatar
"Official Site Skeptic"
Try turning the rubber grommet counter clockwise 1 turn. Its between the instrument panel & choke ****.
Old Jan 14, 2010 | 09:48 PM
scobrother's Avatar
Default hawkeye choke cable
cable was taken off with the carb and is under construction. i just figure out how to get this cable loose. the wall that the choke moves gets stuck and closes really slow.
Old Jan 16, 2010 | 02:19 PM
scobrother's Avatar
Default still messed up
i took the carb completely out and the choke cable is still stuck after I cleaned it. when we spray carb cleaner around it and its running it idles like crazy. it has a vacuum leak in a couple of places. if I buy a new one one will this fix it?
Ty Speece
Jul 2, 2015 04:59 PM
generalpops
Jun 5, 2015 08:23 PM
garyt1975
Jun 5, 2015 08:53 AM
generalpops
Jun 3, 2015 08:25 PM
kevbowe
Jun 1, 2015 01:17 AM
