2007 Jetmoto 150 CVT oil change
I read on the forms here last week of someone wanting do know how to fill the little trans. gear box on 150 CVT machine. Today I was changing oil on the Honda & Jet so I figured I'd see what's in there for oil! I removed the plug and carefully drained all the oil into a little dish. It was actually not bad yet and no filings or anything! The trans was nice and warm and after letting it sit a while draining I got out a bit over 5 OZ. of oil. So to refill I just tipped it on its side and took a little hose on a gizmo I have for measuring small amounts of oil and squirted in 6 oz. of 80w90 gear oil right back in the drain hole Should be good for a few years. The is no fill plug on this model of trans at least that I could find on the top or sides.
I believe this is the latest transmission set up of these Jetmoto 150's The 2006's I saw had a different trans with a fill plug or something on the side.
Other 150 ATV's probably use this trans set up too.
Here's a picture of the bottom of it and the drain plug.
http://forums.atvconnection.com/pict...ictureid=22226
Lou Domenech
Sep 11, 2015 06:35 PM
braap123
Sep 7, 2015 12:58 PM
braap123
Sep 7, 2015 10:57 AM
