2007 Jetmoto 150 CVT oil change
Old 01-04-2010, 11:48 PM
Sawyer's Avatar
Default 2007 Jetmoto 150 CVT oil change
I read on the forms here last week of someone wanting do know how to fill the little trans. gear box on 150 CVT machine. Today I was changing oil on the Honda & Jet so I figured I'd see what's in there for oil! I removed the plug and carefully drained all the oil into a little dish. It was actually not bad yet and no filings or anything! The trans was nice and warm and after letting it sit a while draining I got out a bit over 5 OZ. of oil. So to refill I just tipped it on its side and took a little hose on a gizmo I have for measuring small amounts of oil and squirted in 6 oz. of 80w90 gear oil right back in the drain hole Should be good for a few years. The is no fill plug on this model of trans at least that I could find on the top or sides.
I believe this is the latest transmission set up of these Jetmoto 150's The 2006's I saw had a different trans with a fill plug or something on the side.
Other 150 ATV's probably use this trans set up too.
Here's a picture of the bottom of it and the drain plug.
http://forums.atvconnection.com/pict...ictureid=22226
Old 01-07-2010, 01:21 AM
LynnEdwards's Avatar
Electrical Expert
Originally Posted by Sawyer
...I read on the forms here last week of someone wanting do know how to fill the little trans. gear box on 150 CVT machine...
Here is a link to that thread:
http://forums.atvconnection.com/chin...ml#post2882350
ylomnstr
09-22-2015 12:19 AM
Lou Domenech
09-11-2015 06:35 PM
braap123
09-07-2015 12:58 PM
braap123
09-07-2015 10:57 AM
ylomnstr
09-04-2015 05:02 PM
Quick Reply: 2007 Jetmoto 150 CVT oil change
